Zulu4 said:Interesting. Thanks.
I'd have thought the infamous N52 lifter "tick" would have got a mention.
On the N52 the lifters are infamous for ticking.Fred Smith said:Zulu4 said:Interesting. Thanks.
Tell us what you know about the lifter tick...
Google 'N52 HVA lifter tick' and it will tell you plenty.Fred Smith said:Zulu4 said:Interesting. Thanks.
Zulu4 said:Google 'N52 HVA lifter tick' and it will tell you plenty.
I got rid of mine (mostly) by using Castrol Magnatec or Castrol Edge oil. It occasionally re-surfaces if I don't use the car for a long time.
Just imagine how much fun you could have had if you'd left your drive for those 3-5 minutes.Fred Smith said:It seems to be the case that the tick is definitely caused by lack of use, or perhaps lack of "spirited use". It seems like 3-5 mins idling at 3000 rpm is the short cut method of getting the engine to behave as though it gets proper, spirited use.
enuff_zed said:Just imagine how much fun you could have had if you'd left your drive for those 3-5 minutes.![]()
Thought you were near the Hog's Back? Doesn't have to be in top gear as long as the revs are up.Fred Smith said:enuff_zed said:Just imagine how much fun you could have had if you'd left your drive for those 3-5 minutes.![]()
I did leave my drive.... I went to a park and ride just out town so as not to piss off the neighbours!
I also note that parked up is UNDOUBTEDLY the best way of ensuring that you can run consistently high revs, safely, for a period of time... but yeah, with hindsight if I ever get the tick again I will try the "drive fairly fast and revvy round some country lanes" method
enuff_zed said:Thought you were near the Hog's Back? Doesn't have to be in top gear as long as the revs are up.
Though, tbf it's a few years since I frequented that neighbourhood so maybe it's not the road it was?
I always feel that an engine is better to be revved against a load, not in neutral. But maybe that’s just me.Fred Smith said:enuff_zed said:Thought you were near the Hog's Back? Doesn't have to be in top gear as long as the revs are up.
I am near the hogs back... with hindsight giving her a good blast is probably the best way... but 3 mins at 3k revs is fine too! (Might have done 5 mins just to be sure)
enuff_zed said:I always feel that an engine is better to be revved against a load, not in neutral. But maybe that’s just me.
