simonlpearce
So not a clue what happened, though im blaming the wife as she touched it last :x
Anyhow the flap that you close that hides away the nav/cubby hole area is bust (number 5 in below pic). There is a hinge at the bottom with a plastic pin type thing either side at the bottom, which fits into a groove on the centre console bit to form a hinge and hold it in place. One side of the hinge, the plastic pin, has snapped off and the other isn't far behind.
Looking at realoem tells me you have to buy the entire flap which is going to cost somewhere in the region of £50-£80 :x If there is a know/simple fix then i would rather try that first.
