Thanks!Carsonking said:Just purchased a set of nightbreakers off eBay, so ill let you know how I get on.
srhutch said:Andy, in the end you will need to raise the headlights. All the brighter bulbs do is illuminate the area already lit. I always did mine two complete turns from a known dead centre, and never got flashed.
Just remember to put them back for MOT.
srhutch said:There is a white adjuster next to each light which is accessed from the top using a Allen key. 5mm from memory.
andrewbowers133 said:Hi Derby,
I also did this, from memory it is anti-clockwise but if you park opposite a wall in the dark with your lights on then adjust it you can see which way the level moves.
This is what I did.
Carsonking said:Go with the Phillips, because if you have two working bulbs, it's not worth the hassle or money, IMO.![]()
