Arc8 10"x18 and 9"x18 ? sized tyres
BTZ461
 Christchurch New Zealand
Soo moving these arc8's from the E86 3.0si across to the Z4M coupe, and planning on fitting to this car running standard suspension and geometry : 235 45 18" at the front, and on the rear 265 40 18".
Given the wheel specs are ET 42 at the front, (and one day we just might fit a bigger caliper) going to run with either 15 or 18mm spacer and bolts. And the rear at ET 25 should be just fine.
Any advice from the readers, are we on the right track?
Thanks for reading.
