cbisbi said:
Oops! I have just taken delivery of both the front and rear kits based on an AP employee's opinion that both kits are a direct replacement (no spacers required) of the OEM parts. Is it certain that the front kit fits? Pls understand my ignorance in terms of understanding the pdf AP analysis as to whether wheel clearance is fine...!
Welcome to the forum mate.
With reference to your questions above and assuming it's the M3/CSL kit you bought, i'm afraid you will have to make a few modifications before the kit can fit on your car. All the points below relate to the fronts (356mm) as i believe the rears are a direct fit without any modifications.
(1) The Bells (black centre of the disc which attaches to the hup) will need to be changed as part no for the Z4M is different to the e46. I beleive the revised Bell for the Z4M allows more clearance between the disc and wishbone/lower arm of the car.
(2) Bolts will also need to be changed as again the part for the Z4M is different.
(3) You may also want to consider 19" or a different set of 18" rims such as BBS which give more BBKs clearance as the stock wheels will not/marginally clear the discs (1-2mm at best).
I've spoken to AP directly and that's where the above guidance comes from. I have the part no's for (1) and (2) above and will post them up tomorrow.
