Today I’ve been fiddling around how to access the top of the ST XA dampers to adjust them. The fronts are easily reached in the engine bay of course.
The rears are basically hidden under two pieces of plastic. On top part of the water collection and drain area of the roof. Underneath that the parts that form the hinges of the parcel shelf.
The water collection area is not easily removed, neither is making a hole in that from the top easy. So we drilled a hole from below from the wheel well when the dampers were removed, kind of following the angle of the dampers upwards.
The hinge part is easy, that is removed anyway to undo the nuts that hold the dampers (unless you have installed a reverse type top mounts such as the Rogue Engineering one). With the hole in the water collection plastic already there, I temporary installed the hinge part, draw the outline where the hole should come, removed it again and drilled it.
My initial idea was to add the KW adjuster extensions and route these somewhere. But I realised I would then have a permanent opening in the water collection area. As the hole is a bit higher in the damper ‘bulge’ I don’t think there is a real risk of water leakage, but I didn’t like the idea. Secondly I would have the KW extensions somewhere in the area the roof retracts, and I was wary of interference or possible damage.
I also noticed that the adjustment of the dampers was quite easy to reach with a 2 mm allen key. So now chose to have a more semi-permanent seal of the hole I made, that I could remove whenever I wanted to adjust the dampers (my guess, very rarely...). I measured the hole we made, which was 20 mm, so I ordered some 20 mm silicone ‘bungs’ to seal off the holes.
The dampers are just about reachable through the parcel shelf area. It is a bit tight, but for the rare occasions I want to do this I assume it will be ok.
The hinge part with the hole outlined
After drilling the hole
Both pieces of plastic with holes, and top of damper showing. Top plastic is the water collection area, botto, the hinge part.
With the 'bung' in place. The bung is 20 mm in diameter so fits the hole perfectly, and the top is a bit wider so covers it well. I assume it will hold out any water quite well.
Everything back in place. Tight area, but hope good enough for the occassional adjustment.
