N NeilP Veteran North West London May 15, 2014 #2 ba3bas said: as above - want to reduce body roll Click to expand... should have kept your Smart then and gone and bugged Rob. But I too would like to know this.
M Machine monkey Lifer In the shire Oxfordshire May 15, 2014 #3 I have a e46 M3 bar on mine the front is a straight swap just need the m3 bushes. I used powerflex ones. One of the best mods i have done. I have a rear one but its not a straight swap. But i am looking into making it fit.
M Machine monkey Lifer In the shire Oxfordshire May 15, 2014 #4 Just to say eibach make a adjustable rear one that's a straight swap.
B ba3bas Active member Barnet May 15, 2014 #5 Neil, I still got the Smart mate, my daily run about Mat, you sure the M3 Eibach ones do? I can't find an Eibach one for the Z4 Coupe
B ba3bas Active member Barnet May 15, 2014 #6 as an FYI, my mate is going to fit the Eibach ones to his M3 Although i'd like front and rear otherwise i'd get understeer based on findings. I'd take his old ones if you can figure a way to make them fit
M Machine monkey Lifer In the shire Oxfordshire May 15, 2014 #7 I assume its the same coupe roadster call them? I have got BMW M3 bars front and back not eibach.
B ba3bas Active member Barnet May 15, 2014 #8 im confused you said your looking to make the rear m3 ones fit right? Basically if my mate fits his eibach ones I can take his oem ones
M Machine monkey Lifer In the shire Oxfordshire May 15, 2014 #9 I am confused to!! If you still coming round Saturday i can better explain and show you. But BMW M3 e46 front ARB BMW M3 E46 REAR arb :thumbsdown: but yes i am going to be trying to make it fit. But it would be best to go after market (for most people) on the rear.
M Machine monkey Lifer In the shire Oxfordshire May 15, 2014 #11 My car will probably be up on axle stands so i can show you the issue. And if i have thought of a solution show you that too.
B ba3bas Active member Barnet May 15, 2014 #12 i did find these but I have dips on the M3 ones http://www.demon-tweeks.co.uk/performance/anti-roll-bars/car/bmw/z4/2007/hr-anti-roll-bar-kit-27mm-2-way-adjustable-front-and-21mm-3-way-adjustable-rear
