Looking for someone recommended, ideally mobile but if not then south Manchester area
colb said:Fitted after market seat pads and wiring to my 2.5 manual seats mounted the kit switches in the gearstick plastic surround above the hazard switch. Sourced from ebay @ £16 per seat. To fit its a seat out job and strip the covers off to stick the pads on the foam squab and backrest. Loads of hog rings hold it all together under the covers, some people use nylon zip ties instead of replacing the hog rings, I used new hog rings and a hog ring tool to close them. Picture shows passenger seat squab stripped, thats the occupancy sensor mat, fitted the heat pad over the top of that then put the cover back on hog ringing it to the wires that are buried in the foam to retain it.
https://www.ebay.co.uk/itm/175095934551?hash=item28c487ee57:g:XtEAAOSwGmlgHQ80
All work fine high setting warms up quick, often have to put it on low which is comfy and not too hot.
