Anyone able to help with Carly fault codes?
AnubisZed
Veteran
 Lincolnshire, UK
Evening all,
I've just done a fault code check with Carly and the following fault codes came up....
ABS / DSC / Brake:
Dynamische Stabilitaets Kontrolle / DSC
:Rotation rate sensor / Gyroscope / Speed sensor right front line fault
Code: 005EAC
:Lateral acceleration sensor
Code: 005E96
Systems:
Junction Box Passenger / Beifahrer
Heated seat driver
Code: 00A6E0
Now the drivers heated seat doesn't work and never has the time I've owned it, the fuse is fine and as the heater elements are in two sections I'd take a guess at the module under the seat may be at fault, I'll have to investigate this with my DMM.
Now for the ABS codes, I've tried to find this on 'tinternet but I'm not really coming up with anything positive. Can any of you point me in the right direction? I'm not one for sitting on my backside and handing over loads of "hard-earned" when I can do it myself (if I can!!) so if anyone can help out it'll be appreciated.
TIA
