Hi All,
Ok I have done LOTS of reading on here and all over the net regarding this subject, but I'm still at a loss.
So like many others I have a worrying amount of moisture nigh on sopping wet under the passenger carpet. there is no sign whatsoever on water on the top as carpet top is not wet. any where underneath it is really wet, did I mention sopping, all the seals seem ok as I poured water all over the bleedin thing. no water/moisture seems to be getting in Via the door.
Dismantelled the trim under the glove box removed pollen filter seems dry there, there is foam on the bulkhead and that seems a sad damp but I cannot tell if thats moisture being soaked up or not, I've removed the windscreen cowl driver side drain was massively blocked so cleaned that out, and cleaned up all around the drains on passenger side.
Plastic inlet for air filter seemed like the foam was a little damp so I removed the front of the plastic inlet cleaned it up and put a small amount of black engine gasket silicon sealant on the edge and re-assembled everything and cleaned it up mad sure all the clips fitted properly all around the top.
I really have no Idea what else to do, and to make matters worse putting the big lump of carpet back in the passenger side pulled a cable and broke it.. looks like one someone else put in ( does have a tracker fitted ) think it may be that..
We bought it knowing that the was broken ( I have a new regulator ) slow air weep on 108 rims ( being sorted this Saturday ) and what with having to replace the ABS Sensor on the front left and the two pressure sensors on the master cylinder.. I'm fecked off with this German crap box.. bmws reliable. well built.. really.. sorry I love the car it's great, 1 owner from exdemo Full dealer service history seemed like a right deal at £4.5k with 89k on the clock for a 2004 car.. just miffed withmy first 3 weeks of Z4 ownership.
Please help where else can I look?
Can I remove the carpet just on the passenger side? is it easy to remove the seat?
Any advice on the leak I will NOT be beaten..
