You could dive in and find a problem with the loom, but if the motor hasn't been moved yet then you may as well start with that.bigwinn said:Is motor relocated? Classic signs of water logging first but could also be a loom/sensor failure?
Something you can do? Or do you need help?MKZ4000 said:The motor isn't relocated.
MKZ4000 said:The motor isn't relocated. I was just trying to rule out any easier other reasons for the short circuit on the button code
There's a chance it is the loom tbh, but until you get that motor out and check you won't be sure.MKZ4000 said:Thanks Guys. I’ll get RBM to relocate the motor. Just wanted to check anything else that might have thrown up that fault code rather the dodgy motor
