wanatkinson said:
I think I will replace these first and see what happens
That's my general recommendation for all 2009/2010 Z4.
Apart of your individual issue, these MS can fail due to the aging of that little spring on the microswitch, that is spreaded to max when the lid is closed. And that is 99.9999999% of the lifetime of the Z4. 8)
And, these failing MS can force the hydraulic pump to run continuosly until it dies due to overheating. That situation is not checked by the CTM.
There are some pifalls:
- mark the exact position of the 3 nuts on the coupling locks, use a fine white or silver edding pin to mark around these nuts
- the small 3 mm inbus(!) screws are glued and in most cases have to be drilled out with a 3mm drill
- you need 4x M3 inbus screws with a lenght of 10mm, two of them have to be shorted to a lenght of 5mm
- the new microswitches have a newser plug. Cut the new(!) plug housing, take the pins out of it and put it into the housings of the old MS
