Another Newbie Here
JimRob
 Stratford Upon Avon
Hi All,
Purchased this beauty Friday and haven't stopped grinning. It's the 2003 2.5i manual and I believe has the M-Sport suspension and seats. Not 100% sure as the ride is much better than I was expecting and what I had read about. It's done 81k and has all the kit (electric heated leather, Sat Nav, etc), and is in really nice condition, and does not show it's 17 year age. It has a full service history and has only covered 8k in the last 5 years, so it needs running in. There are a few issues I knew about when I bought it and will obviously be looking to you guys for some advice. Stuff that needs doing:-
1. Passenger side electric window not working, can't here any motor noise when pressing button, could this mean a complete new regulator?
2. I get a beep beep beep continuosly when in reverse. I do have parking sensors but they seem to work ok, and produce a diiferent beep when approaching an object. Are they related?
3. 3rd brake light needs replacing, starting to pull away at the edges but you can only tell when close up, but this looks an easy fix.
4. Very slight flacking of paint around bottom of front bumper, not really a concern but may look at getting this sorted at some point.
5. One of the previous owners has vinyl wrapped the front part of the dash in carbon fibre, and is starting to peal in places, will probably remove and replace with similar wrap as it actually looks quite nice.
Absolulty loving the car, and looking forward to going to some meets when all this madness is over.
Cheers,
Jim
Hi Jim and welcome to the forum
Regarding the reversing sensors, could someone have fitted one of those warning beepers for when reversing, is it loud and can you tell where the sound is coming from.
With the window you could probably do with removing the door card and checking for voltage at the motor.
Well done with posting photos it looks very nice
Hi Chippie
Thanks for the welcome. Yer it's pretty loud and as you say it sounds like a reversing beep from a lorry!! It seems to be coming from the behind the dash, I will investigate further. At some point I will remove door card and check motor, but as it's the passenger side I can live with it for the moment. Thanks..
Hi and welcome to the forum Jim.
Your car looks great with those refurbed wheels. :thumbsup:
Mine is 2003 too and the drivers window wasn't working. The garage that I am buying it from is fixing it for me though so I can't really offer any advice other than I've heard a few people say about problems with the windows so it must be quite a common fault.
Your car looks very nice, you must be so pleased with it.
Welcome to Z ownership and the forum. Lot’s of info on here, the wheels really suit the car. Have fun.
Just coming back on the parking senser reverse beep. It does seem this is a reverse warning beep, coming from behind the dash. When aproaching an object the parking sensor beeps start up and the reverse warning beep stops, and when the object moves out the way the reverse beep start again. I tried all sensors with my hand and all seems to work ok. Strange...
Just a thought, but are your parking sensors OE ones?
My 2nd Coupe had been retro-fitted with non-BMW sensors and used to beep once every time I selected reverse, but then they worked as normal.
Luckily a forum member with Carly managed to code them so I didn't get that beeping beep! So if you know anyone who can do coding it's possible you might be able to get yours recoded.
Welcome to the forum. :) A beauty indeed. 8) :thumbsup:
https://z4-forum.com/forum/viewtopic.php?t=113602
Link for the center brake light.....
I presume they are OE as the car is fully loaded with every option, so I would have thought the original owner would have specified them. I hope to spend 99% of my time going forwards so I can put up with it for a while, until I find someone with a Carly reader.
Ordered new clear centre brake light from ebay, contemplated buying original BMW but decided to take a punt on the cheap Chinese copies.
