So I've had a strip of White LED's for some time now (no surprise some might say).
Anyway after recent posts I ordered 1Metre of white 5050 LED's. They arrived today and after some family time I've already fitted them.
I didn't want to hack any of the cars wiring so I chose to employ this method.
Take out the existing LED boot light
Remove the first resistor from each side and solder on some tails. After this pic was taken I put a tie wrap round them to ensure they stayed in place.
I then joined these tails to the ones from the led strip. As I couldn't find my heat shrink tube I used bullet connectors. I then fed the modified light down the back of the carpet above the light (easy job) and plugged the bulb back in and then attached the strip to the top of the boot.
End result, a boot which you can see in when it's dark. And a completely reversible mod.
