Oof.. Don't envy you that.. My underseat sub took an hour with just 2 trim panels removed
still it won't be a patch on your system...I honestly could not be arsed with that
Bravo mate
Bravo mate
Bravo mate mr.tourette said:Oof.. Don't envy you that.. My underseat sub took an hour with just 2 trim panels removedstill it won't be a patch on your system...I honestly could not be arsed with that
Bravo mate
Alan Crook said:Wow some really clever people on here,love reading all the build threads. Audiofile incar are doing my upgrade this week as its way too much for me to take on. Subs look really good in there.
Zed Baron said::happyclap: well done, very impressive
mr.tourette said:subs look great mate, a really clean install and I like the tucked away gain dial in the cubby..top work![]()
No, it's either high level direct speaker connections or low level via the MOST fibre optic network.Bmwrottie said:Does the stock head unit have RCA outputs I can take straight to an amp?
Wrong section bud, this is the E89 (2009 - 2016) section. You'll be best off in the E85/6 section808bimmerZ4 said:Hey guys! I bought a 2003 BMW Z4 3.0i and it does not have a working amplifier. It was burnt and the previous owner did not care to replace it. What would be the best replacement for the amplifier? what other remedies should I do for it? I have installed the aftermarket head unit with back up camera, everything works including the back up camera view but just the sounds not working because of the amplifier. Please let me know. Thank you!!!
Bmwrottie said:So I tried taking the high level inputs from the footwell woofers.
This did run a spare seperate Amp and mid speaker, but it won't run an active subwoofer (all in one underseat thing) which is what I was wanting to install, and I don't understand why not.
Surely the footwell woofers aren't filtered above what it would take to run subwoofer?
This is what I'm trying to run tapped into footwell woofers.
https://nakamichicaraudio.com/products/nakamichi-nbf8-1a?_pos=1&_sid=181eefe15&_ss=r
Bmwrottie said:[ref]AnubisZed[/ref] love your videos on YouTube!
Re my issue here:
Do you think it's because I only have one speaker input?
Bmwrottie said:Just one Amp was testing the other to make sure the wiring set up works.
Thanks for the help guys. Does anyone have the speaker wiring diagram? Trying to figure out which colour wires are for which speaker
