coupedan said:The condition of the tyres plays a massive part when doing a wheel alignment, it could knock the geometry out by quite a bit if your tyres are unevenly worn to start.
BUT....
Am I right in reading that you are running 225/45/18 up front and a 255/35/18 at the rear?
Was the alignment done with this tyre set up?
Also, just to point out... your handling issue only started in February? Was this about the time when you changed the rear tyres?
Dan
Hi Dan, thanks for commenting.
That is the setup I am running for now. The alignment was originally done with 225/45/18 up front and 255/40/18 rear. That's when they advised that my rear tyres needed replacing. After replacing the rear tyres the alignment was re-checked. So to answer your question, the alignment was re-done with my current tyre setup.
The handling issue started in Feb/Mar. I put the new rear tyres on last week. When the issues started I had not changed anything or added anything new to the car for months.
