Silverstar said:But yours has the N54 not the N52 as per the OP's also his doesn't have the DCT, his has the ZF 6 speed.
Troo ! Good catch.
Silverstar said:Marcoose said:OP, unless you just had an oil change and the indy will save and reuse the engine oil, you should budget for an oil and filter change. Which would be the right time for it. Heads up, the N52 is finicky. My indy recommends oil change every 6 months. Which I’ve done since buying this Zed. Since your car is up, ask the indy to check DCT leaks.
B21 said:Silverstar said:Marcoose said:OP, unless you just had an oil change and the indy will save and reuse the engine oil, you should budget for an oil and filter change. Which would be the right time for it. Heads up, the N52 is finicky. My indy recommends oil change every 6 months. Which I’ve done since buying this Zed. Since your car is up, ask the indy to check DCT leaks.
Don’t let facts get in the way of opinion !![]()
It wasn't an opinion, it was a mistake. He then held his hands up to the error.B21 said:Don’t let facts get in the way of opinion !
