Aluminum Flywheel for E89 Z3 35i? Where to find and experiences?
GuidoK said:
I'm having a hard time to believe that the required size is 7/16" what he says tbh on a german car, and the way he describes bleeding a clutch is also not correct. That is the correct bleeding procedure for a brake caliper.
On a clutch slave cylinder you let the clutch spring remove the fluid and not the pedal. He's now only removing air from the line but any air in the cylinder if present wont be removed.
These are basics you have to understand if you want to do a job like this.
I also dont understand why he didnt use a socket to open up that bleeder if he didnt have a flexhead wrench or crowfoot. I mean he doesnt use a bleederhose to collect the fluid. There are multiple options to tackle this minor problem....
He doesnt strike me as the most competent mechanical genius tbh.
At least he didnt waste a good tool. A 7/16 wrench is best destroyed if you're in to bmw's :rofl:
those yanks.... :roll:
and if you dont have a transmission jack you shouldnt be changing gearboxes. Sure it can be done but its far too heavy to even come near any H&S regulations to lift it that high. Especially a 6 speed (and with an automatic or dsc its sheer impossible unless youre hulk hogan).
A transmission jack costs 80 quid or so. Thats nothing compared to the price of your tools or carlift or garage/workshop.
Yes, the kid is a newbie (good natured one) but he's green. I like the video because it shows me what I'm up against before I get there. There are other videos and discussions of this on other forums....all say it is a PITA. Yes, bleeding slave is the same for bleeding brakes. Get a rubber tube and attach to small catch can and pump and bleed. Problem with a socket is you can't have a socket and bleed tube on at the same time.
I will try the valve delete option and see how much that helps. Otherwise an aluminum flywheel and short shift kit may be next on the list.
After much research... I know what and how a DMF is and works but, it seems once I learned what the function was of the weighted flywheel, what the benefits were of a lightened flywheel, and where the happy medium was in which materials ..... (phew) .... I then learned all this good stuff is not readily available for the lowly 3.0 E89 :x
So I'm leaning towards a refresh of original function using LUX parts. With a couple of minor mods.
Valor1 said:
Hi!
I find the clutch / flywheel feel on this car to be the main detractor from a more direct feeling sports car feel. I want to replace the dual mass boat anchor with lightweight clutch and flywheel assembly. I'm surprised there does not seem to be anything out there for this car (I have a 2009 SDrive35i).
Anyone know of a good one? Has anyone tried tried it? Thanks!
I know this is an old thread but in case you are still chasing the solution then the biggest improvement you can make to responsiveness on the N54 is to remove the throttle dampening in the ECU. The throttle dampening table was found earlier this year by comparing the ECU data with that of the 1M.
You need a custom map created to take advantage of these tables as they are not something many tuners have access to.
