Deepseaskateboard said:Silverstar said:Deepseaskateboard said:I have found the part for this, but it costs more than the other three pedals put together!
Do you have a link to it?
Sure: https://www.ebay.co.uk/itm/174207320362
JamiesZ4 said:I went for the non drilled ‘push on’ pedals
Deepseaskateboard said:Ok, finally got around to fitting the set.
It took me one hour 45 mins to complete, from tools out to tools put back!
It’s a pretty hard job which requires at least a five week contortionist class prior to attempting.
I found the mini ratchet to be essential, as well as a strong metal cutting drill bit.
Deepseaskateboard said:JamiesZ4 said:I went for the non drilled ‘push on’ pedals
After tiring out muscles I didn't even know I had, I don’t blame you! Looks smart!
Silverstar said:Deepseaskateboard said:Ok, finally got around to fitting the set.
They do look good!![]()
Are you happy with them? Is a template to drill the holes provided or how did you do it?
JamiesZ4 said:Deepseaskateboard said:JamiesZ4 said:I went for the non drilled ‘push on’ pedals
Cheers, likewise your new pedals look great too!![]()
mkinternet said:Looks really good - just need the dead pedal to match![]()
Deepseaskateboard said:Silverstar said:Deepseaskateboard said:Ok, finally got around to fitting the set.
Yeah, very happy.
I am surprised actually, what a difference they make.
There is a template yeah, just cut it out and stick it on.
It’s a bit fiddly drilling, as the pedals under the rubber are grooved slightly, and both were metal.
I used the template, but then placed the pedal over the hole to double check the positioning.
I am looking at the dead pedal now... would be great to get that sorted the same. I am thinking a custom cnc job.
.... thinking being the key word!
Silverstar said:Deepseaskateboard said:Silverstar said:They do look good!![]()
Yeah, very happy.
This forum is making me add more things to my list of pending mods![]()
Deepseaskateboard said:Silverstar said:Deepseaskateboard said:Yeah, very happy.
Haha the Pedals are a good one!
After the wind deflector, my wheels need some love.
The list is never ending!
I know what you mean. I have to say though I am enjoying tinkering around and doing mods to this old car then having a brand new car which I would be more cautious about taking apart or if it's on a PCP or lease you can't touch it at all.Silverstar said:Deepseaskateboard said:Silverstar said:This forum is making me add more things to my list of pending mods![]()
Deepseaskateboard said:Silverstar said:Deepseaskateboard said:Haha the Pedals are a good one!
I am tempted by the front splitter, but also think the Z4 is pretty good as it is. I have not done much:
BMW Stubby Aerial
Boot LED (replaced the useless stock bulb)
BMW aluminium pedals
In progress: OEM wind deflector
To be done:
Floating centre caps
Paint Callipers (either clear lacquer, silver or black)
Change break discs and pads
Wheel refurb
New tyres (none run-flat possibly)
Aluminium valve stems
Mulling over:
LED footwell lighting (oem)
Puddle lights
Then I want some stone chips removing.
I have re painted the drivers seat bolster, and gone over some of the interior with a coral red leather paint, looks really good now!
List of jobs goes on and on, but it’s a bit of a hobby!
Beeacon said:Apparently, getting pedal covers for an E89 is difficult work and no one has done it before! ...At least, according to my rudimentary google-fu.
Most kits for a 1/2/3/5 series are very easy if you have a manual or automatic transmission for all the pedals. It's a different story for the footrest/dead pedal covers though, as no one seems to do one for the E89 nor is there a part listed on realoem (at least, not that I could find). So I set about trying to find the closest approximation and went from there.
So I set about some research and came up with the following. I searched for all configurations while I was at it just to help you guys out should you consider some pedal covers.
Accelerator pedal:
Automatic/DCT - The side of the pedal is a lot deeper than on the manuals, otherwise dims are identical. Any pedal cover will work as long as it fits an automatic transmission, this part number (35426859999), or these models - 1 series (F52), 3 series (all E90s), 5 series (All E60s, All F10s) (all automatics)
Manual - Manual pedals are different in that they don't have the kickdown switch at the end of the pedal, so the cover must be for a manual transmission, this part number (35426860000), or these models - 1 series (F52), 3 series (all E90s), 5 series (All E60s, All F10s) (all manuals)
Brake Pedal:
Automatic/DCT - Any pedal cover that fits this part number (35211160421) or these models: All 1,2,3,4,5,6,7,8,X1,X3,X4,X5,X6,X7,Z3,Z4,Z8 series (literally everything)
Manual - Any pedal cover that fits this part number (35211160658) or these models: All 1,2,3,4,X1,X3,X4,Z3,Z4 series (except the G29)
Clutch Pedal:
Manual - Same shape and size as the manual brake pedal, so any pedal cover that fits this part number (35311160659) or these models: All 1,2,3,4,X1,X3,X4,Z3,Z4 series (except the G29)
Footrest:
All E89s - This is where it gets tricky as no one actually makes one for the E89 shape.
I measured some dims to get the best approximation, and everything I've seen online seems to be out for the E89 or no dims at all.
I have found the below, which I think is the best approximation, but I believe it is still a little too wide, but I think I will give it a go and see. I think its worth a leap of faith for £30.
https://www.aliexpress.com/item/32800716626.html?spm=a2g0o.productlist.0.0.4e2414453gOVpz&algo_pvid=5acb484b-ba21-4523-b9d1-2e66dc9e76c5&algo_expid=5acb484b-ba21-4523-b9d1-2e66dc9e76c5-6&btsid=0b0a119a15934292572974118eaf5e&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Silverstar said:Deepseaskateboard said:Silverstar said:I know what you mean. I have to say though I am enjoying tinkering around and doing mods to this old car then having a brand new car which I would be more cautious about taking apart or if it's on a PCP or lease you can't touch it at all.
BMW Stubby Aerial
To be done:
Wheel refurb
Mulling over:
Puddle lights
Your list is almost similar to mine. Work already done:
Refurbed Alloys and new centre caps
Bumper painted and bottom grill areas colour matched
Painted calipers and hubs
Stubby aerial
Full interior and boot LEDS + extended LED strip in the boot
OEM footwell lights (my car didn't come with extended lighting package) I was thinking about the door puddle lights but I can't be asked to wire through the doors etc.
Full professional detail with multi stage polish and ceramic coating
Instrument cluster LEDS changed to white and F80 M3 / M4 style gauge faces
Coded door mirrors to close with key, Digital Speedo
OEM Wind deflector fitted (the central part, I am still looking for the hoop inserts)
Osram cool blue angel eyes bulbs
Carbon Fiber interior dash and door trims
Dash Cam
On the pending list as when time and funds allow:
ECU remap
Gearbox remap
Those alloy pedals!
Upgraded sound
Eibach / Bilstein suspension kit
Some sort of sports exhaust (undecided as yet which)
Maybe just maybe 19" alloys
I have thought about adding spoilers and splitters side skirts etc but just like you at times I think the car looks good the way it is and I also worry how those parts affect the aerodynamics of the car. I mean most of these manufacturers of spoilers and splitters don't wind tunnel test them so what effect they have who knows. If anything I might go for the BMW M Performance style front splitters for my standard (Non M Sport) bumper.
