fernando306
Hello my friends,
Can you please check if I am not forgetting anything, before I pull the trigger on these parts?
-> Is there any "conflict" in doing this, for example, a bit higher ground clearance may call for different sway bar links or height level sensor? Something crazy like that? :roll:
Obviously the goal is to renew shocks and convert to non-sport suspension: A bit more comfy and ground clearance is welcome as this is my DD.
1 - All four Bilstein B4 struts: $397.99
https://www.eeuroparts.com/Parts/507692/Suspension-Strut-and-Shock-Absorber-Assembly-Kit-Front-and-Rear-Standard-Suspension-B4-OE-Replacement-3815606KIT/
2 - Lesjofors non-sport coils front $71.99:
https://www.eeuroparts.com/Parts/509905/Coil-Spring-Set-Front-Driver-and-Passenger-Side-without-Mtech-3993779KIT/
3 - Lesjofors non-sport coils rear $105.29:
https://www.eeuroparts.com/Parts/510123/Coil-Spring-Set-Rear-Driver-and-Passenger-Side-without-Mtech-4001700KIT/
4 - Two Front strut mounts Lemfoerder 2730901 $46.58
https://www.eeuroparts.com/Parts/168373/Strut-Mount-Front-2730901/
5 - Two Rear strut mounts Lemfoerder 2585301 $17.98
https://www.eeuroparts.com/Parts/87477/Shock-Mount-Rear-Upper-2585301/
6 - Two Rear Lower spring pads: $15.18
https://www.eeuroparts.com/Parts/356353/Coil-Spring-Pad-Rear-Lower-33531094518A/
7 - Two Rear Upper spring pads: $29.38
https://www.eeuroparts.com/Parts/33290/Coil-Spring-Pad-Rear-Upper-5mm-33531136385/
8 - Two Front Spring pads: $27.58
https://www.eeuroparts.com/Parts/28535/Coil-Spring-Pad-Front-Lower-31331096664/
9 - Two Front Spring pads: $22.98
https://www.eeuroparts.com/Parts/10372/Coil-Spring-Pad-Front-Upper-31331128523/
Thank you
Thank you
