buzyg said:
Rocket said:
I charged the battery for 24 hours with my CTEK charger, I gave it a full reconditioning charge. I locked the car this morning with the interior sensor activated and it has been fine for 3 hours. I have not moved the car since I was getting the alarm going off a couple of days ago. The battery came with the car when I bought it and I'm sure the guy said he had put a new one on while he owned the car, I guess it is 4 or 5 years old. Fingers crossed low voltage was the problem. (the car started fine so the battery was not flat). If the alarm starts going off again I will post again. The car is getting no use at the moment but I have been starting it every few days and running the engine for 15 mins or so. During the winter I charge it every week or two with the CTEK.
Your Zed will sit happily for weeks without need to run the engine. Just keep the battery charged. The most likely thing to give you issues when not running, aside from the battery, are the brakes binding. Better to take it round the block when we can, as that warms the gear box and running gear through.
As a general rule of thumb, I have always worked on the understanding that it takes around 7 miles of normal driving to put back the charge used to start a car.
I will admit that this info came to me a good 35 years ago, and things have moved on a bit since then, but I am still sure that just starting and running a car for a short while may not do the battery a lot of good.
Plus, as mentioned, you need to get everything warmed up properly to burn off any condensation as well.
