If the clutch on the compressor is not engaging (you should be able to see it spinning or not), check electrical connections on the connector to the clutch and at the clutch itself. I have seen many in the past with broken or damaged wires at the business end. However, if the revs don't rise when the a/c is switched on at tickover, it is most likely a control issue as you said.Lynx said:Yes I turned the centre wheel above the vents to blue, fans start straight away, but I can't hear any change when I turn the aircon on. I've done some research on how to test the compressor clutch with a multimeter, so I'll give that a try tomorrow, but it looks like it's going to be the compressor that's the problem.
Lynx said:Hello
I take it that when the new compressor is delivered and fitted, that the clutch will engage while there is no gas in the system, as it will not be worth taking the car to get the system Flushed and Re-gassed if there is still a problem?
Also I will strip the old one down when it's off and see how this compressor works.
