flybobbie said:Well having played around to day, don't think it makes much difference.
Mainly i think switching ignition on and letting what sounds like the valvetronic cycling has made it run better.
I guess you do a lot of roof down motoring then :rofl:Marcoose said:I feel my cars have far more pep after I eat a can of beans. Even more if I add a couple of hard boiled eggs.
No way! That would be a horrible waste of fuel. That's my ERS, mate. :rofl:Zed Baron said:I guess you do a lot of roof down motoring then :rofl:Marcoose said:I feel my cars have far more pep after I eat a can of beans. Even more if I add a couple of hard boiled eggs.
Valvetronic motor changes the exhaust valve timing, bolted above exhaust on the N52 engine.Smartbear said:I’m not sure the valvetronic system can cycle with the engine turned off as it relies on oil pressure to operate? :?flybobbie said:Well having played around to day, don't think it makes much difference.
No they don't.abar121 said:Doesn't the A/C compressor turn off when the car thinks it's wide open? Most cars do this as well as for heat management.
No it didn't.abar121 said:The car thought it was flat out (or close enough), so kept turning the A/C off.
flybobbie said:Valvetronic motor changes the exhaust valve timing, bolted above exhaust on the N52 engine.Smartbear said:I’m not sure the valvetronic system can cycle with the engine turned off as it relies on oil pressure to operate? :?flybobbie said:Well having played around to day, don't think it makes much difference.
Someone on YT replaced their cars motor and did the 10 second ignition on to cycle it, i suppose so it can find the end stops.
I put ignition on can hear a motor winding in and out.
My car certainly received an instant tune up.
The voice of sanity and climate protection, I salute you sirtomscott said:If you've got the top down there's no need for aircon![]()
Pondrew said:No they don't.abar121 said:Doesn't the A/C compressor turn off when the car thinks it's wide open? Most cars do this as well as for heat management.
The a/c compressor is controlled by a) the a/c button and b) the pressures switches on the refrigerant lines. That is all.![]()
That makes no logical sense to my mechanical mind, apart from a stalling scenario. Please explain whyPbondar said:The IHKA unit ( heating and control unit ) fitted to the E89 can be commanded by the DME to switch the clutch on the compressor off for 10 seconds if full throttle is applied below 10 mph.
Pondrew said:That makes no logical sense to my mechanical mind. Please explain whyPbondar said:The IHKA unit ( heating and control unit ) fitted to the E89 can be commanded by the DME to switch the clutch on the compressor off for 10 seconds if full throttle is applied below 10 mph.![]()
OK. I can see the acceleration map, maybe, possiblySmartbear said:Less mechanical drag for maximum engine performance i guess
Pondrew said:Under 10 mph?Smartbear said:Less mechanical drag for maximum engine performance i guess
I thought about my response and changed it. Do you maybe want to do the same?Pbondar said:You are correct you are dumb..
