Read good reviews, wasn't sure it would be a good over the air map though compared to on the rollers?Vanne said:Yep. Randy at Epic will set you right.![]()
Are you running an airbox with evolve map then? Did they ever sort the heel n toe issue?Ed Doe said:Evolve will also map for an airbox, as well as PSDesigns. I do not have experience with either of them in the mapping department, but in terms of answering questions about my existing evolve map, I've found Evolve to be very good. PSDesigns also were very good in terms of customer service when I ordered an RTD Shifter kit from them...
RedUn said:Are you running an airbox with evolve map then? Did they ever sort the heel n toe issue?
Will look into PSD, cheers![]()
