Airbag light
Scrapman
Hi all
Just removed my steering wheel to fit new royals steering wheel and after reconnecting the battery and starting the car the airbag light has come on???. Any thoughts as I never had a problem before I removed wheel ( followed the guide on here so hopefully I did it all in the correct way)
Regards
Scrapman
Then there's a high degree of probability you didn't connect it up correctly or damaged the connector/harness removing/reconnecting.
You'll need to have it reset and if it stays on fix the fault and have it reset again.
Best an indie or someone with software
