Airbag light on!
goody
My airbag lamp is on, fault codes for under voltage, in the srs page and airbag lamp in the instrument cluster page. I reset the under voltage one an it will clear and come back with no errors on the next scan. the airbag lamp code won't clear it's still there and the lamp is still lit. Could it be a faulty instrument cluster? Thanks for any help!
Go for a ride in your lockdown, once a day, exercise period. 5 Or 6 miles should do the trick. When you switch off and back on light should be out. This happens with mine when not had a good run for a week.
