Airbag light code 9886 and 93E7
stekar
So codes same left knee bag at variance and second code is low voltage but after investigating I found a wet floor passenger seat and a damp left side module with signs of corrosion. Could this module cause this fault and is there an alternative part number as I cant find the module with my part number anywhere 65 77 6928571 01. I am aware this will probably need coding afterwards thanks innadvance
Other than the part number you have, you can look for either of the two in the 'superceded by' section on here.
https://www.realoem.com/bmw/enUS/partxref?q=6928571
Mine also got wet, became corroded and threw up random errors, a replacement off ebay of the 3985 version is now in and recoded and all is good! So far....
