I have a child seat in my passenger seat most of the time. I turn the key at the side of the dash and that light illuminates when I start the car. Is it a button too? I haven’t pressed it.
Yeah, in light cluster in front of rear view mirror. I only discovered yesterday.
Still don't understand why, when the usual key switch is in the dash also ???? :?
Where's the logical Pondrew when you need him, he'd know
I guess if you want it permanently disabled you turn the key in the pillar.
But if you are quickly swapping between adults and a baby seat then it's a real faff to dismantle the key, insert the metal bit in the door pillar etc. Much easier to push the button, which I assume resets each time you turn the ignition off?
How wierd, went to test to see if resets on restart and now the button not lighting up !!?? :?
Probably why i never noticed it before.
Must have been a fluke yesterday. Although i turned on and off the ignition a few times and light flashed each time.
Strange.
