robertboeke
The airbag light has come one. I've tried clearing the code with DIS44 and INPA and I can see the light go out for a second and then come back on as the "error is currently present".
The codes I'm getting are:
sbsl 983e control module fault (this is causing the airbag light according to INPA)
sbsl 9858 control module fault (this alone would apparently not cause a warning light)
I think these errors mean I'll need a new sbsl control module (most likely used from ebay unless someone reading has one. Part code 6933985). Which will then need the vin setting using WinKFP, then will need coding to the car using SSS and then possibly another clearing of the errors using INPA/DISv44.
I've got most of the software (still need to find WinFKP), but just wanted to check whether anyone knows of anything else I should check before spending money and hours fixing this, or whether I'm missing any steps. Thanks.
