Hi all
Right this one has me flummoxed. Tonys car...
I'll tell the story I know abridged as there have been multiple efforts to sort the issues prior to me getting at it!
The main issue was an airbag light appearing on the 03 2.5 E85. So prior to me looking at it I think the following happened:
- water ingress diagnosed, nearside airbag module swapped for one with the same code
- several auto electricians tried to clear the light
Tony and I chatted and he popped over last weekend for me to recode the new module (assumed this would resolve the issue)
Ran codes, cleared faults- light went. Result.
However the airbag light then relit. No issues- went on to recode the new module using WINKFP.
Light would not go out. Used Carly and INPA to diagnose seat occupancy sensor issue- thinking thats the root cause and Tony telling me it first came on when the seat was moved/sat it I got a bypass sensor and fitted that today.
The light persists.
When I look at the codes now it is saying ERROR_ECU_GENERAL_REJECT on SIM85
See screenshots- all pre start tests are OK. As far as I can read the control modules are not talking to each other?
When I try to go into individual airbag modules on INPA I can access the main overall area, but not each subsequent area (like airbag left/right module etc)
NOTE- to revert the system to its pre-issues status I have reinstalled the original nearside module, so the system is back to how it was, seat bypass installed.
Anyone got a view what I should attempt or look at next please?
The light persists.
