Airbag (and Intermittent Battery) Light - Code 986B
EViS
The red airbag light has come on our 2003 e85 with the following code coming up during a scan:
Code:
00 986B - SBSL: Resistance , firing circuit, thorax airbag, rear left (E85, E60, E61), or knee airbag, front left (E63, E64) too high
The following codes are also present and may be of relevance?
Code:
00 003D - GM: Boot-lid unlocking: mechanism
00 008A - GM: DWA alarm memory: passenger-comp sensor, front
I had a similar issue last year with fault code 987B. This was rectified with a replacement (used) SBSL module and the airbag light has remained off ever since. Additionally, for a number of years, the amber battery light will intermittently show for the first couple of minutes and then turn off. Could these faults be in some manner linked?
Don't think those other codes are linked in any way.
However, given the issues a duff battery can cause I think I would be starting by looking into swapping that.
Hopefully your replacement SBSL hasn't died. :cry:
The very intermittent battery light is a pain and I've been waiting for it to throw a code, but none have surfaced that can be directly linked.
The battery is a shy less than 5 years old and still within it's Varta warranty period. I don't think it's at fault, but I am open to trying a replacement.
Also, worth mentioning that I can clear the airbag light and is stays off until the second cycle. The previously faulty SBSL wouldn't ever let me clear the light as it would immediately return on the first cycle.
Even prior to a replacement battery, is there anything else you may recommend looking at?
I had a similar code which was caused by the wiring in the door connector. Slight corrosion meant it triggered every so often
May be worth some electrical cleaner
I'll investigate this, thanks for the tip. Is the plug that you refer to behind the door card and membrane?
The one in the door frame- where the electrics come out of the door and join the main car loom
