well last night i thought id go over my cousins barn/workshop and get a load of small jobs done that i cant do in the dark on my drive....
1st up was a quick air filter change... upon taking the top off i noticed the box was a little loose/wobbly, so could somebody clarify if this hole in the bottom should have a fixing in it, or if its used for some type of drainage? (if its a fixing then ill need to source a replacement bracket/fixing)
then after a quick blow out and hoover and replacing of filter, i noticed that the pipe attached was broken, so ive temporarily glued it as best i can but ideally want it replaced, am i better off just getting a replacement pipe or should i just upgrade the whole box/filter while im at it rather than waste my money on stock OEM stuff?
i also tried fitting fang protectors but didnt have any screws to suit (i dont have //M corners so cant just screw in) :thumbsdown:
wanted to fit 1st aid boxes but ran out of time :thumbsdown:
but i did also fit all new LED interior lights
and repaired a broken lug on my headlight
..... but discovered about half a liter of water in headlight as there's a massive hole i need to fix
(where lug broke off) but this will all be photographed and documented when i repair it and another thread
