Air filter and spark plugs?
toledo
Hi Alpinaheads
I want to change the spark plugs and air filter on my Roadster but I'm not finding it easy to work out exactly which spark plugs and air filter I need to buy. Can anyone help?
When I search online for an air filter a "Pipercross" one comes up but I'm presuming this is not the same as OEM would be. Also would be interested to know if anyone has tried something like a GruppeM setup or got any opinions on them? Always up for anything that gives me a bit more noise but don't want to damage the engine.
Many thanks for any help you can give.
Sean
Try going on the ecp site and put your reg number in it should give you some options.
Also try realoem for info :thumbsup:
Thanks mate, will give it a go. Hopefully the Alpina VIN will work because a lot of sites just seem to come up with "2005 BMW" when I use the reg or don't recognise the Alpina VIN. If I use the original BMW VIN they just think the cars a standard 3.0 Zed.
Cheers :thumbsup:
Your local BMW dealer can tell you the part number - else give Sopers a ring (01522 690000) and tell them you're looking for a quote and part number for both. They also offer the forum discount if you decide to go with them.
For extra noise, its pretty limited. I've tried the piper cross, gave a little more raspiness but not much, so I soon discarded it. If you're after a GruppeM or Eventuri type roar, I haven't heard of either having a fitment for the Alpina engine (S52B32) intake, let alone the remap.
Thanks markeg! Went for OEM in the end - Mahle LX343 air filter, NGK BKR6EQUP plugs, cleaned out the airbox and a quick clean of the MAF sensor with this stuff: https://www.amazon.co.uk/Liqui-Moly-Sensor-Cleaner-200ml/dp/B00295EEBK/ref=sr_1_2?ie=UTF8&qid=1493301840&sr=8-2&keywords=maf+cleaner
Idle definitely smoother and less lumpy now :)
