Aftermarket Xenon Selection
OK so PIAA xtreme white do seem a bit expensive, the phillips or x-treme power or osram silverstar then anybody?
I put a set of the H7 HIDs I got from ebay on my wife's 525i, which had halogen bulbs with projector lenses. The HID kit claims to not give error codes since the ballast takes care of it. Installed in about 1/2 hour and no error codes. The kit was $70 shipped. they have been installed for over a year without any problems. These are not bi-xenon in the 525i since it uses a H7 for the high beam.
Aftermarket standard bulbs that claim to be 50% brighter are not going to compare to a HID system. They usually don't last very long either. I did get a set of Phillips Vision + bulbs in my 4 runner, which are just a little brighter than stock, and they claim 50% brighter.
I'd go with the HID, they will make the biggest difference in light output.
I fitted HID's to my E36, bought them from Cromelinedesign. Ben who runs the company sponsors one of the E36 forums so does good deals. I went for 7000k but 6000k appears the most popular for the perfect white look. The ballasts are waterproof and whilst I can't comment on the Z4 layout, I was able to screw them down to the back of the bumper reinforcement and the cables are not excessive or difficult to feed to the headlights.
As for the legal aspects, I too looked deep into this. Yes, it's a very 'grey' area. You don;t need to bother with all the self levelling and washers etc as that applies to 'supplied new' vehicles. HID produce a different beam pattern to Halogen and this is where the bad reputation of aftermarket kits comes from. ie the people fitting them to regular headlights such as Ford and Honda and many others that do not use projector headlamps. Therefore, the HID beam pattern hit the Halogen glass and the glass projects the beam pattern to the Halogen pattern and knocks it all out. When you fit the HID's to projector headlamps, the beam pattern remains the same and does not cause problems.
You simply take the H7 bulbs out, fit the H7 shaped HID bulbs and connect up the ballasts. I can't comment on error codes as my E36 doesn't have that option. As long as you get the headlamps aligned properly (your local MOT guy should be able to do this) the beam will not obstruct other road users and will work in the same way as regular Halogen, but brighter with a much crisper white light.
Never had a single problem with my HID's and as I'm a member of the E36 forum, the sponsor gave me a lifetime guarantee so any problems, he will fix free as long as they are fitted to the E36 and in my possession. Now that's a confidence guarantee! I've never had anyone flash me and never been pulled over for having them fitted. Sailed through the MOT and only needed slight adjustment as I'd just fitted the 17" alloys.
Of course, whilst you are 99% safe, there will always be that one strict MOT tester, or that police person who has had a bad day or just wants to be a pain, but you get that with whatever you do. In general though, it's a pretty safe risk to take.
I've tried the '50% brighter' halogen bulbs and wont bother ever again. Yes, you fit them and think they look great, but a month down the line you forget and begin to wonder if they have dulled down or if you just got used to them, with HID you notice the crisp white brightness every single time you turn them on.
And I've had mine fitted for about a year now and covered just over 20,000 untroubled miles.
get a cheap HID kit, take a chance...i did and it worked
now i have fitted bi-xenon projector(with working bi-xenon components) utilizing the old ballast, still no prob.
used aftermarket ballast to D2S wiring converter
works well...super bright... no complaints :)
OK well for the time being I've just adjusted the headlights up 'a little' so next time I am out in the dark I'll see if thats made any difference...
I think for the £30-40 it is for the '50% brighter bulbs' it may be worth doubling that and going for the aftermarket xenons but I am still none the wiser as to what manufacturer to go for...
