Advice needed please
casleeder
Got into the car this morning and nothing coming out of the speakers through Radio / CD / Bluetooth.
Im guessing it could simply be a fuse - not had chance to check yet, but the head unit is working fine.
Anyone ever experienced similar?
Lee
Common fault used to be water in the boot where the Amp sits in a plastic tray. if your car has had problems with a leaky roof or blocked drain holes then water can get into the boot and end up filling the tray where the amp sits those corroding it. If this happens then they can be a right mare to get hold of.
Thanks.
It has seemingly rectified itself (for now?) but will definitely check the boot/amp at the weekend. I've recently fitted a hardtop so I'm inclined to think it won't be that, but an old M3 had drain hole issues so will look at that.
cheers
check this fuse
https://www.newtis.info/tisv2/a/en/e85-z4-3.0i-roa/wiring-functional-info/supply/high-fidelity-amplifier-supply/q-F102
