Advice for a newbie
OK so we've just purchased a 2012 2.0i sDrive MSport for my good lady - pick it up when we're back from our hols in a couple of weeks. The one thing I will want to get for it are some rims and winter tyres. From the dealer the car is on M Sport 19" rims with 225/35 at the front and 255/30 at the rear. In terms of winters I'd prefer to put the car on 17" rims which I believe to be standard fit on the Z4 with a tyre size of 225/45 17. Now this is the first time we've ever had a car with different size tyres front and rear. So am I right in assuming (I know the rolling radius is right) that, with the winters, I can have the same size tyres front and rear when the M Sport wheels have different sizes front and rear? Having had a good trawl through it seems that this is OK, but confirmation would be great. Also, it appears that all these different BMW rims are identified by their numbers. What should I be looking for in terms of the identifying numbers for 17" BMW rims when I start to look for a second hand set of BMW 17" rims. Thanks in advance for any advice that long-term Z4 owners can share.
Hi and welcome to the forum :thumbsup:
There's a number of 17" alloys that will fit your Zed try - http://www.realoem.com/bmw/enUS/select
Put your details in this should tell you what was originally fitted by BMW
Thanks for that metal licker. Very helpful site. The 19" rims are the original factory fit although whether they were standard or a customer option at the time I have no idea but I assume standard as BMW designate the model as the M Sport. Either way this has certainly helped me understand the rim options and which BMW numbers fit the car in a 17" version.
If I understand correctly then the 276 and 290 rims are only available as an 8J x 17 (ET29) front and rear. These would obviously run 225/45 17 tyres.
But the 292 and the 514 rims come with the option of fitting an 8J x 17 (ET29) on both front and rear (running 225/45 tyres); or you can fit those rims on just the front and fit an 8.5J x 17 (ET40) version on the rears. Now I know you can put a 225 on an 8.5J rim but it's not ideal with a 235 or 245 preferred. A 235 would be OK from a rolling radius perspective, just a 1.4% variance from the 225 - so well within the tread depth variance.
So, is it better to go with 8J rims all round, with 225/45 tyres? Or better to go 8.5J at the rear and fit 225/45? Or 8.5J at the rear and fit 235/45? Any observations or suggestions as to the pros and cons of these choices would be appreciated.
