Adjustable rear control arms needed?
Argenta
Hello!
In the process of switching to Eibach's as everybody seem to like them.
They lower 10mm in the rear, will I need to adjust toe or camber? I.e. order a pair of adjustable lower control arms?
If so I might just change them at the same time I reckon. I am a bit picky about correct tracking etc.
Cheers
Per
also, if the shop tells you they cant get it in spec (wheel alignment) probably means your fcabs and Rcabs are a shot duck.
