Additional USB or 12v socket
Arthur_
 Wiltshire
Hi all
Iv just installed a phone holder in my e85 and id like some advise on what's the best way to add an additional 12v socket or usb so I can plug both my bluetooth receiver which runs off a 12v plug and my phone charger which needs a usb.
Id like to be able to have them both plugged in and be able to have the ash tray lid closed which would also mean id need to run the usb cable into the ashtray compartment somehow.
Many thanks
Arthur
There's a removable panel just above the ashtray, I've fitted one there and wired into a ignition live on the fusebox
I fitted a twin usb socket with built in volt meter, obtained via ebay, drilled the plastic dash behind the steering wheel and in line with heater controls, then wired unit to cig lighter as that was the closest power source rather than go all the way across to the fuse board. I would have positioned it slightly better if doing it again as the steering wheel spoke tends to mask it from my view with the wheel set in the position I use.
https://www.ebay.co.uk/itm/12Volt-Dual-USB-Car-Cigarette-Lighter-Socket-Splitter-Charger-Adapter-Power-Plug/353130621818?hash=item523839ab7a:g:Kf0AAOSwn1tfArhv
Jamie-innes said:
+1 on putting them on the removable trim panel :thumbsup: also a cheap part to replace as they're only £15 on ebay
That looks a very neat solution. May have to add that to wifey's car.
Could you please tell me where the two wires go to?
Thanks.
Thanks.
Thanks mate :thumbsup: and my headunit has 2 USB ports which this socket plugs into
Thanks.
Thanks. Something I'll need to look into. Much neater than the old cigarette lighter socket that means you can't shut the lid down.
enuff_zed said:
Thanks.
I agree, I've also got a small 10cm usb cable and a phone magnet stuck to that panel so it tucks away nicely while im using android auto :D
Hi Jamie
Where did you source the squared double socket? I can't find anything flush like that which isn't circular! Thanks :thumbsup:
Darkangelv2 said:
Hi Jamie
Hi mate, it took me ages to find one too :rofl: this is the one I bought from amazon,
https://www.amazon.co.uk/gp/aw/d/B07DDB1KM3?psc=1&ref=ppx_pop_mob_b_asin_title
