I pray I am spared this issue.Rucky said:The brushes in the electric motor that drives the pump. They commonly fail and cause the ABS pumps to malfunction
Thanks pal
So what did they do to cure the spongy brakes then?DennisW said:I have been out on a test drive with my garage man and I am satisfied that brakes are ok. You have to beware purchasing second hand pumps as they need to be programmed in to your ECU and apparently this is not an easy thing to do.
smorris_12 said:He's talking out of his ar$e. If the ABS pump isn't activated then the brake pedal feel should be exactly the same as not having an ABS pump there.
