Hi, I've had the FDF0 error code up for a while now (intermittently) so I've done lots of reading for diagnosis so will shortly be sending the unit off to have the bushes replaced. So, my question is how do I bleed the brakes afterwards? I've bled lots of brakes before on motorbikes so I'm proficient with this, but not with an ABS pump. I can't find a how-to on this forum, and I've read that it needs software to do this (I assume for it to activate the pump in order to remove air from it), so is my only option taking it to a garage? In which case, I would obviously have to take the car there before removing the ABS pump, so that also means they would have to charge for the removal and fitting of the pump which I would have otherwise done myself.
Any other options? Thanks
