sammysquid
GuidoK said:BM54, not BM45.
BM54 is the general type of radio used in (among) the e46. It is not 100% the same as the z4 unit, but probably enough.
I don't know for sure, but I think the inputs of the amp are low level.
Soldering in other amp ic's in the HU certainly won't give you the soundquality given by a seperate amp. A seperate amp is an amplifier/booster (thus boosting the voltage to get more (and more undistorted) power), and the HU doesn't have that type of schematic.
You're basically getting average headunit quality from something like halfords. Probably better than a standalone OEM HU, but nowehere near the quality and power that the hifi prof dsp provides.
And in a convertible, that is something you'll notice (in a convertible you need more power as both the background noise is much higher and the open roof makes the acoustics very different (open field conditions versus closed room)
So yeah the basic stereo is the same from what I understand. Inside the stereo there is a set of amps, now... what is popular is to bypass those to give you low level inputs for adding pre-outs, if you use a high to low level converter the sound quality is meant to suffer, because you are amplifying distortion through the system - The reason people add the pre-outs to the stereo is because of the decrease in quality offered by a high-low input converter - the high level output has been messed with by the EQ.
The amp issue... it started because the BM54 has amps that die. The replacement amps are meant to actually be really good and the feedback from people who have done this mod is really quite high. The basis for wanting to go with this route would be that you wouldn't need to find space for a separate amp or high to low converters and you would find that the quality is better. You also wouldn't have to run as many wires around the place.
The OP isn't going to get the power from the hifi-dsp as the dsp amp is gone, and if you read the reviews again the bmw DSP system is not highly regarded in terms of DSP, with suggestions it is tinny - again not my thoughts but reviews from other people. Regarding the soldering if separate amps.... well you're actually installing a small amp board, it is only 40w rms I think, but that is all you need, yes it won't give you the power of a nice separate amp I agree but then you are going to be sticking with standard speakers so realistically how much wattage do you think you need?
I think you could do the setup for less than £200. and with only one actual standard class D sub amp. The other options here are very complicated and will maybe not give you the best quality.
I stand corrected - if you use http://www.ebay.co.uk/itm/Audison-Bit-Ten-Signal-Interface-Processor-DSP-Car-Sound-Audio-Processor-BitTen-/310630757579?pt=UK_In_Car_Technology&hash=item48530934cb
that is meant to make it nice... but its not cheap!
I think the other option which would strongly appeal to me is to remove the standard headunit or maybe just mess with it a little - you have a tablet installed so could you not just use that for sound? and then maybe hide an amp and the like behind the stereo fascia?
