A696 code SOLVED *** and an interesting fix
bigwinn
 Lincoln UK
Site Supporter
Hi all
A696 code showing won’t clear
Roof movement preceded by ‘bong’ and roof movement impaired message on I drive and red icon on dash
Roof movement starts but:
Roof stops once on way down just before the mech stores itself into the boot and once on the way up just before the front shell hits the screen
Changed both hall sensors on the ram- problem persists
I’m guessing that now needs a full wire check?
I can’t find the wiring diagram on TIS anyone got one?
Cheers
Stuart
Hi Stuart,
Thanks for your mail.
⌛ E89: Collection of the 7 typical age-related defects in the roof environment
https://z4-forum.com/forum/viewtopic.php?t=148657
If you orientate on this list, the microswitches on the couplings should be replaced as well.
RobbiZ4 said:
Hi Stuart,
Roger that Robbi
Will do
I’ll report back
Curiouser and curiouser as Alice said
There have either been rodents in here or previous 'works'
The wiring for hall sensor HS2 (I think that's the correct one for A696 as opposed to HS1 for A691) has been rewired from sensor to the plug direct
I am going to check for continuity and resistance- what should I be looking for values wise?
Can anyone confirm that the wiring should go from the sensor to pins (37 for Brown) and (29 for Red) please however these colours may be incorrect due to rewiring... possibly was yellow/brown???
Also this wiring generally looks crunched yes?
your view please?
been for a walk and a think
the A696 code persisting I think is a red herring and the two issues instead of being related may be different...
So, I am going to replace the two microswitches to see if that solves issue one of the roof on its way down
then check the hall sensors relating to roof closing I haven't done yet, which are 1203 and 1243
See what that yields
Stuart
Have a look at the correct assignment:
Roof fault A696 Hall sensor
https://z4-forum.com/forum/viewtopic.php?p=1843524#p1843524
Oki
Pink relays swapped- no change
Microswitches renewed- no change
Rear hall sensors renewed- no change
No obvious issues with the hall sensors on the shells but new ones coming from BMW will rule them in or out
So back to square one
Someone somewhere had the same issue and symptoms but never reported back what the findings were
https://e89.zpost.com/forums/showthread.php?t=2048403
Or is it actually wiring that is the issue…
https://e89.zpost.com/forums/showthread.php?t=1529701
Indeed, check the wirings.
But, did you by this car already with roof faults?
Black 26-pole connector
HS-1
Pin 8 brown (signal)
Pin 21 grey (VCC)
Black 41-pole connector
HS-2
Pin 37 brown (signal)
Pin 29 red (VCC)
Important for all connectors of these hallsensors:
color to color (i.e. yellow to red)
brown to brown (!)
Checked the wiring elbows on the roof shells and I can’t see any breaks either side
Calling it off today
It’s still got me pulling a face that it stops in exactly the same place every time
Could this be a cvm issue? Or do I just need to go for my dinner
Running out of options
Wiring checked for breaks- none evident
Anyone got any other bright ideas?
It’s possible that any breaks are only showing at a certain point, bend in the roof cycle, you could try running a pair of new wires taped to the outside of the loom from each hall censor, micro switch in turn back to the roof module, starting with the most probable culprit and working your way through just to be certain that the loom is in good order.
Good shout Mick
I’ve done that with the errant sensor already (hall sensor on the ram that always fail) back to the module pins
Right lads. A salutary lesson here
Robbi is (rightfully) the guru on the e89 roof- his constant mantra of sensors and microswitches are the absolute start point for us all and should not be ignored
However when your gut tells you something else is the root- don’t ignore it
The consistent fault with this roof said to me sensor, microswitches, wiring or control module
Having ruled every other route out, last to try was the CVM
This isn’t supported by conventional thoughts on the e89 community. However seeing modules continuing to degrade on the e85s, for the sake of 250 quid I tried a new module
SOLVED
All errors and persistent gremlins gone
It seems that the age old module problems are starting to show on this generation car
Thanks for the help and pointers everyone and Robbi
Picture of the removed module which looks like someone had been in it before…
Stuart
There have been quite a few CTM induced failures recently …obviously it’s a bigger ticket item and it’s not an easy diagnosis without an A B swap..
Good you bottomed it out.. :thumbsup:
Well done!
This "old" but already replaced CTM looks a bit worn out, doesn't it? The two labels actually point to an eBay replacement part.
So far, I haven't seen any evidence of defective CTMs as a general problem. But who knows...
RobbiZ4 said:
Well done!
I’m personally aware of 5 CTM failures FWIW
B21 said:
RobbiZ4 said:
Well done!
I don't count those damaged by water/corrosion.
RobbiZ4 said:
B21 said:
RobbiZ4 said:
Well done!
Ah I do..same type of mysterious faults… :thumbsup:
