dk345 said:Hi all,
Yesterday morning I had the unhappy privilege of rounding a blind bend and finding myself on a stretch of road covered in snow and ice. I wasn't going fast, as it was wet and 0.5 degrees out, but the rest of my journey did not contain such dangerous conditions so I just wasn't expecting it.
Couldn't slow the car in time, got onto the snow and ice, fishtailed, couldn't hold it, went off the road and into a farmer's field a four foot drop away. Car went nose first in, bounced onto passenger side, and then landed on the roof.
Amazingly I was cut free by the fire brigade and able to walk away from my car. My injuries are no more serious than a few cuts and bruises, and a bit of whiplash.
I am a lucky boy and probably owe my life to whoever at BMW was responsible for engineering that roof and the other safety systems.
Stay safe out there guys. I'm well aware I got away with this one - lucky I'm able to post this at all.
MrPT said:... Think I might buy one of those hammers/belt cutters too.
TomK said:Sorry to see the car like that, they do engineer these B pillar things quite well thankfully, I've also had that experience before.. twice :lol:
But, you say you crashed coming off a road packed with snow and you land in the adjacent field, which doesn't have a drop of snow on it by the looks of your picture? :?
Busterboo said:MrPT said:... Think I might buy one of those hammers/belt cutters too.
If the OP's experience is common to the Z4 and the belt pulls very tight in a major accident, then a cutter's obviously essential.
Have also bought one for the wife's Fiesta, anyway.
dk345 said:Re: the seatbelt. I assumed it was just holding me in tight because of the impact and the fact I was upside down, but now that I think about it I thought one of the design features of a seat belt is that it's easy to undo in case the worst happens and you need to get out quick...
MrPT said:dk345 said:Re: the seatbelt. I assumed it was just holding me in tight because of the impact and the fact I was upside down, but now that I think about it I thought one of the design features of a seat belt is that it's easy to undo in case the worst happens and you need to get out quick...
They have a pyrotechnic pretensioner that yanks you back into the seat when a big impact is anticipated. You should still be able to unbuckle them though. Was it the case that the buckle was out of reach or jammed?
Smartbear said:Maybe it was because the op was inverted & his weight was bearing on the belt?
MrPT said:They have a pyrotechnic pretensioner that yanks you back into the seat when a big impact is anticipated. You should still be able to unbuckle them though. Was it the case that the buckle was out of reach or jammed?
dk345 said:MrPT said:They have a pyrotechnic pretensioner that yanks you back into the seat when a big impact is anticipated. You should still be able to unbuckle them though. Was it the case that the buckle was out of reach or jammed?
Yeah, I remember reading about how pre-tensioners work months back. I could reach the buckle release easily, but pressing the button down (well, up) was met with resistance and it wouldn't budge.
Don’t forget to bolt down all such items. What seems like a good idea becomes a lethal weapon as the car rolls or crashes as it flies around. I know from rolling Jeeps and seeing a friend injured from tools hitting himBusterboo said:The AA window-breaker & belt-cutter has arrived and will be in my car from now on.
As will the fire-extinguisher that I ordered with it.
obewan said:Busterboo said:The AA window-breaker & belt-cutter has arrived and will be in my car from now on.
And if it's not stating the obvious - within reach as well![]()
If the belts pulled tight there are only a couple of places you could get the belt cutter from
Buckz said:that's quite worrying.. lucky that you were in the dry but imagine being in water, you'd be gone in a couple of minutes.
