A huge long shot but......
Vanne said:
Depends on what your after..
Good morning,
I'm after a passenger side headlight, mine has a crack on the inside metallic silver part plus the outer plastic lense isnt in the best of shape.
blunderthumbs said:
Are the headlights not the same as other Z4's then.? Why does it have to be a Z4M specific headlight :?
Unfortunately they're not. The z4m has bi-xenons with the halo ring sidelight.
I think a normal z4 just has a standard xenon.
Any facelift xenon should be the same regardless of model AFAIK though RealOEM suggests only the 3.0si headlight is the same part number as the M.
I don’t believe this is correct, I think you will find that they are the same on m and non m versions depending on the car specification. Mine for instance has bi-xénons with halo ring and it is only the 3l non m version.
Please see the below for the difference between Pre and post facelift Bi-Xenons
https://z4-forum.com/forum/viewtopic.php?f=7&t=121599&p=1739963&hilit=xenon#p1739963
enuff_zed said:
I just like the fact that you consider non-M cars 'normal'. :D
I didnt mean anything in a badge snobbery way, I'm certainly not one of those who do that. I remember being on m3 pages on fb where owners would literally rip the crap out of someone if they posted a really smart 330 or something. Having owned such cars myself I still admire them.
There’s someone on eBay breaking a Z4M - not clear what parts are left but may be worth sending them a message.
https://www.ebay.co.uk/itm/124137222975
Also, Quarry Motors break BMWs and usually have a fair amount of stock. Don’t think you can buy online, so might be worth a phone call.
http://www.quarrymotors.co.uk/
I stripped the insides of my lights, would those parts help you? Igniters, the whole bit. I just kept the casing.
Yeah, I've tried them both. Cheers for the idea though :thumbsup:
To be honest its the casing, well the lense which is the problem, mines gone a funny colour plus there is alot of grit inside for some reason. The silver internal casing part has a crack in it. Very annoying.
