supersebbo
OK, so a few things that have not been able to work out so far...
1) Driveway lighting - in my old car I could tell it to turn the headlights on after I got out the car at night and it would leave them on for a set amount of time (adjustable) so you could see your way across the drive in the dark. I've enabled Home Lights in the iDrive menu but this hasn't seemed to make it work, the DRLs were on after I turned the ignition off but as soon as I opened the door they went off. Can this be done??
2) Is it possible to set the passenger wing mirror to auto-tilt down when you select reverse? I thought this was standard but it doesn't seem to be doing it, can you adjust the position too?
3) How do you adjust the volume of the navigation directions? They are very quiet no matter what volume the stereo is at.
4) In the manual it says that there is a 'convertible function' to the climate control system (page 112). In my Audi this meant I can set a different temp and vent settings (to pump warm air at my upper body for example) and it would automatically switch between that and the regular settings as the roof was opened or closed. How does this work in the BMW? What does this 'function' do?
Thanks!
Thanks!
