Yes I know you said that but I dont see how 2 small ridges in the bonnet will create significant downforce.Gustavo7 said:I think you missed the point on my Cd vs downforce features of the z4m but that's fine.
As for the diffuser I think its very debatable if that acts as a diffuser. The ducts originate at the rear of the diff (where the diff heatsink obstructs the airflow) and then it vents out at the rear. A diffuser only works if an airflow is created that has a speed significatnly higher than the driving speed of the vehicle. I cant see that happening with the diff heatsink in its path (and the gitter at the end). Thats why I think that that diffuser is more like ducting to guide away the heat from the diff to ensure the diff is cooled enough.
Even the normal z4 diff already has a finned cover with a similar scoop guiding air to it in the bottom tray, and thats an open diff with less power and that already can get pretty hot (too hot to comfortably touch after a spirited drive).
The z4m has a clutch operated lsd that gets much hotter (due to the friction of the clutch, and of course due to more power) so cooling becomes a real issue (therefore it also needs thicker oil). Normally performance cars with a clutch lsd have a seperate diff cooler (so piping and a radiator) but bmw does it this way. But I just cant see air flowing faster through those heat sink fins than the speed of the car, and that is imho a must to let it work as a downforce creating diffuser, because you can only create underpressure/ground effect by higher air speed than the vehicle speed.
Besides that there are no differences imho.
as for diffusers, this is imho a 'real diffuser':
Where there are long unobstructed ducts underneath a car with a flat underside. Thats where a real underpressure can be created by accelerating the air
And 99% of diffusers you see on current cars are more of a fasion fob not actually contributing on downforce.
you know, like this
or this
