Hi guys,
Recently had warning lights that pop up then go off fairly quickly, bloody parking sensors have stopped working as well. The hard top fault and misfire I knew about. And the warnings for the rear axle oddly don't throw up a dash warning, and the rear brakes are absolutely fine. Passed MOT recently with no problems. I don't know if it's due to water somehow getting into the boot perhaps?
It was a rear end shunt repair before I bought it, and had an issue with it where the fuel sender relay was knackered with water ingress. They replaces all the boot seals and replaced missing grommets.
Anybody got any ideas?
Fault code: 00D39F :Embassy TRANSMISSION DATA (ID: 0xBA) – Timeout
Fault code: 005F13 :Lining Wear: achieved rear axle wear limit. / Lining Wear: rear axle wear limit reaches --- (DSC: Lining Wear rear axle brake pads) / Valve supply voltage too low / CAN message error ARS / Lining Wear error: achieved rear axle wear limit
Fault code: 005F11 :Lining Wear: Sensor Check rear axle failed. - BBV Fuehler staked / Lining Wear: Sensor Check rear axle failed. - BBV Fuehler staked --- (DSC: pad wear sensor rear axle) / Lining Wear: Rear Axle Sensor check failed. - BBV Fuehler staked / Controller internal: MIRAM AD update failure / CS820 Vorsorgungsspannung sensors / Coding error: EEPROM Configuration: ACB: Hill Descent Control value in EEPROM invalid. / Lining Wear error: Sensor check rear axle failed
Fault code: 00A696 :Hall sensor VSW7.3 / Hall sensor VSW6.3 / Hall sensor VSW8 / HallsensorVSW8 / Control buttons Close
Fault code: 00E71D :CAN message status PDC / Can embassy status PDC / Embassy (KCAN: Status Air SH / ZH auxiliary water pump, 2EC)
Fault code: 0029D2 Misfiring, Cylinder 6
