A couple of free bits
  • Start date Start date
A
Anonymous
Guest
Hi all.
Having a clear out and found a couple of bits that can go to a good home.
These were both working fine when I last used them but can't confirm 100% they're still good. I have absolutely no reason to think there'd be any problems though.
Genuine BMW aux cable - this came with a replacement panel that fits under the heater controls/above the ashtray. I'm still using that part though you can cut a hole to fit. I can get the dimensions if it helps.
eBay special OBD2 scanner - handy little dongle for a quick read or check of your computer data. This is a WiFi model and I believe it only works with iPhone.
Go on, I'll even cover the postage.
Do you reckon that’s all you need to add aux to a z4 that doesn’t have it already? I’ll take it and give a donation to the forum. Cheers
It should be yeah. PM me your address if you want it
