82mm 50 Years of M heritage badges x2
Ldale
Purchased from eBay so not OEM, originally to fit to the 5 series but never fitted as one of the badges was not perfect when I finally got around to fitting.
Second badge is perfect and never opened, both badges the faces are perfect with the protective film still attached, just peeled back 50/50 for the pic.
The pins on the back of the one look to have been damaged and bonded back on as pictured so did not fit the 5 quite right and if I was been super picky (which I was) the same badge does not sit perfectly to the base plastic around a quarter of the edge however as pictured thats been a bit picky and given those are clearly copies and not OEM could be tolerance.
I played with fitting to the side repeaters on the Z4 which requires removing the pins (so no drama with the one badge with poorly aligned pins as they would be destined to be removed) but did not quite like the look against the colour of the car when I mocked it up.
I think (but please do your own due diligence) an 82mm badge will also fit the rear badge on both E85/86 again by removing the pins and double sided tape.
£13 for both delivered within the UK given one of the badges looks to have a history but if your removing the pins anyway and using double sided tape will be useable.
