5th gear super unleaded test
chrisj900 said:
ben g said:
i used to use tesco's normal unleaded, but had quite a lot of white smoke coming out the exhaust.
changed to tesco momentum (99) and no more smoke.
worth the extra 5p per litre to me.
might give it a try if it reduces the exhaust smoke. mine looks like a train when it gets cold outside
it definitely reduced the smoke a lot.
white smoke came out of the back even on warm days, which was odd.
switched to 99 ron and have filled up about 10 tanks now and it's perfect.
JVE89 said:
I believe in Germany you can fill up with Shell V power racing 100 RON. Wish we could get that here :D
You can also get Aral Extreme which is 102 RON, for about €1.80 last time I tried some.
It didn't seem to make any difference on the M though - so I assume the M can't take advantage of anything higher than 98/99 or that it needs a couple of tanks to 'learn'.
Although it did make me believe I could abuse the car a little as I'd treated it to a bit of the 'good' stuff :P
